Can't run FIFA International Soccer
Reply 60 of 105, by zelenog
How do I get a hold of a floppy version of FIFA International Soccer, by using Google?
Reply 61 of 105, by VisitntX
Ok, when i told you about a floppy version that means the game in a rar file with all the files of the game together (not merged) so you only have to install the content in a folder and mount it in the dosbox easily. By the way i really don't know a cdrom version of FIFA 94. When I say google that is a search engine coz i can't give you the download link for that game here (copyrights and that sorta of things) so you use something like google to find the page where download the game. Winrar could "install" rar and zip and 7z files that are the more commonly in the internet so you shouldn't have problems by now.
Reply 62 of 105, by zelenog
OK, I understand. I also tried to find a website to download FIFA 94 (aka FIFA International Soccer), and I was able to find only 1 site, but they ask you to pay for it 🙁
Oh well, I'll keep looking. At least I know now that it is possible to get a floppy version, and that it should be easier to run it.
It seems like I am going to need that floppy version because I am having problems running the CD version on dosbox 0.63 too 🙁 It does seem much simplier than trying to run it using dosbox 0.65 or 0.70, but it's still tricky.
Can somebody help me?
Here's what I did:
1. typed "mount d: d:\FIFA"
2. typed "d:"
3. typed "dir.exe"
4. typed "FIFA.EXE"
And the window just dissapeared, and game never ran. Did I miss smth? What should I try?
Reply 63 of 105, by zelenog
Please disregard my last reply. First of all I downloaded a FREE FIFA 94 on Internet 😀 and it is running very well. I did the same steps as for a CD version and floppy version works, but CD doesn't 🙁 I'll keep trying something out and hopefully I'll make it run too 😀
Thank you everyone for your help. It would be possible without you, guys!
Bye
Reply 64 of 105, by VisitntX
2. typed "d:"
3. typed "dir.exe"
4. typed "FIFA.EXE"
4 Is wrong, in cd version you must install the game so you should:
First you have to make a folder in your hard disk called like GAMES so that will be your C: coz you will need it.
1. "mount d: d:\FIFA"
2. "mount c: c:\GAMES"
3. "d:"
4. "dir"
5. Find and install.exe
6. If doesn't exist an install but only a setup you will never install it from dosbox coz don't work the setup.
Reply 65 of 105, by zelenog
Really? Thanks for the info. I'll try that. The floppy version is good, but the CD is better. I was told that it has better music and sound effects, player editor, commentary throughout the game and a bug fixed when it is easy to score after a goalkick. So, the CD is way better.
If you could guide me through, that would be great. If diskette version is working, I see no reason why CD version would not work, you know. It is a brand new CD, bought from CDaccess.com and I am sure I am doing something wrong, and it can be playable.
Anyway, I'll try and let you know.
Reply 66 of 105, by zelenog
Ok, I am alittle bit confused. You said that I need to make a folder for this game, called GAMES, but I already made that folder, only it is called FIFA
Let's start from the start. Tell me exactly what I should do. Should I first install the game fro hard drive to C drive and make a folder called GAMES?
Or do you want me to use dosbox and run installation and create a folder from DOSBOX?
I am not very techy, so if you could tell me exactly step-by-step, click-by-click what I need to do, I am sure I can make it run.
Also, setup.exe doesn't exist on cd version, but there is install.exe so we should be able to run the CD version.
Please reply
3. "d:"
4. "dir"
Reply 67 of 105, by VisitntX
Yes that was my fault. I don't give you a very good explanation.
Well the CD games must to be installed, so you have to install the CD version of FIFA 94. But the games are installed in the C:\ in a folder created by the installers. So first you have to make in your XP in your hdd a folder called something like GAMES, that could be intended like your C:\ for your dosbox games, not only the FIFA 94, you could use it for all your games so you don't mess up your hdd.
After create that folder you must go to the dosbox.
And here comes the steps:
1. mount c c:\games
2. mount d d:\ -t cdrom
3. d:
4. dir *.exe
5. "find a file called install.exe or setup.exe that must needed to install the game"
6. "Follow the process to install the game, if the install ask you about a folder to install you must write something like "c:\fifa94" so that will be the place where the game will be installed"
7. c:
8. cd fifa94
9. dir *.exe
10. "find fifa.exe"
11. fifa.exe
But here we come with two troubles. One is the sound config that you should perform from you XP and not from dosbox coz doesn't work in the emu. The same you did before.
But the more annoying trouble is that if there doesn't exist an install.exe and only the setup.exe that file could stop the emu coz doesn't work there. So you should only and really only do the following procedure if you can't install from dosbox:
1. "open your FIFA 94 cd in XP not dosbox"
2. "run the setup here in XP"
3. "install in a folder called C:\GAMES\FIFA94"
4. "config sound from XP the way you did before"
5. "run dosbox"
6. mount c c:\games
7. mount d d:\ -t cdrom
8. c:
9. cd games
10. dir *.exe
11. fifa.exe
That must do it for you. Well I hope this time you could run it.
Remember that you could use other name for the folder GAMES, but must have 8 characters that folder or you will be in more troubles. So better try to use that name. And see how when I use mount don't write mount c: insteed mount c coz you don't need the : there, only in the part after that c:\games that are really needed.
Hope you luck.
Reply 68 of 105, by VisitntX
And I know you said that only exists install.exe not setup.exe but I have to cover that. And remember that the folder GAMES isn't your FIFA folder is the C:\ folder for the dosbox needed to the install to make the folder FIFA94 there.
Well I don't know if you understand what I'm saying coz my english sucks. Sorry for that.
Reply 69 of 105, by zelenog
No, no.. it's very clear what you say. I'll definately try what you said and will let you know today or tomorrow. Thanks for your time and effort!
PS. I really like those classic DOS games. They are so much fun and bring a lot of good memories 😀
Reply 70 of 105, by VisitntX
Me too. Far better than the games of nowadays.
Reply 71 of 105, by abyss
I have the genesis version. I could have got the dos version but it's hard to get running. I got the geneis version in 2006 before i heard about dosbox.
Reply 72 of 105, by VisitntX
FIFA 94 for PC can't run in machines Pentium 2 or equivalents and after that.
Reply 73 of 105, by VisitntX
hey zelenog, worked?
Reply 74 of 105, by zelenog
I was kinda busy these couple of days, but I am definitely trying it this evening and will let you know.
Hopefully, it will work. I'll try it with all 3 versions of dosbox, just in case.
Reply 75 of 105, by VisitntX
Please only try it in the 0.63 the other two will hang up. Really that game works only and only in dosbox 0.63 and in QEMU and machines type Pentium I to bellow.
Reply 76 of 105, by wd
Rank DOSBox Author
DOSBox Author
The cpuid feature is buggy so this might actually work with older
versions. Besides that it works fine with the prefetch core.
Reply 77 of 105, by VisitntX
I heard it and tried it but it didn't work for me. I guess that was my fault so i will try again.
Reply 78 of 105, by wd
Rank DOSBox Author
DOSBox Author
Well if it works with 0.63 for you no need to bother further.
Reply 79 of 105, by VisitntX
No, really if it worked in 0.70 i want to make it run in this version. I just have to try more things.
