STTNG: A Final Unity Installation Guide for DosBox
Reply 60 of 112, by kstabell
I've tried that already and it gives me the "sosDIGIInitDriver" error as a result, I think the thing to do is to get the setup program to work properly but I don't know how.
Reply 61 of 112, by swaaye
It doesn't make sense for you to have problems with my config file as long as you're running the game in DOSBOX. Your install must be missing files.
To get the install program to work, all you need to do is get the nextgen installer replacement that I've attached to the first post of this thread.
Reply 62 of 112, by kstabell
well what seems to make sence and what works seem to be two diffrent things, atleast for me
Reply 63 of 112, by swaaye
I added a comment to my prev post about getting the installer working. You posted too fast. 😉
Reply 64 of 112, by kstabell
I already used the modified install program, everything went fine until the setup stage after copying all the files, that's when the first error occured
Your CD-ROM drive has not been detected or the game CD-ROM is not in your CD-ROM drive. Please insert the game CD-ROM in your CD-ROM drive and try again.
Reply 65 of 112, by swaaye
Are you installing off of a CD or off of a CD image? If a CD, is it the 2CD or 1CD version of the game?
Reply 66 of 112, by kstabell
I have the original CD and it's a single disc
Reply 67 of 112, by swaaye
Ok, here's my super dooper "skip the install program entirely" method.
Get your CD out. Open up the STTNGINS.ZIP file on the CD and extract it to the folder you want to install the game to. Also copy the STTNG.ZIP file there (don't extract this). And, finally, grab my pre-made STTNG.OVL file from the first post in this thread and put it in the folder too.
Make this STTNG.INI file in the folder:
Audio=SB16
Port=0x220
IRQ=0x7
DMA=0x5
Video=HI16
DPixel=ON
Path=.
CD=.
Sound=ON
Music=ON
Voices=ON
Movies=ON
Advice=0
Dialogs=OFF
VolSound=0x7FFF
VolMusic=0x7FFF
UniVESA=OFF
Game should work. 😀
In DOSBOX.conf, I recommend setting "sensitivity" to about 500. Otherwise the mouse is way too slow. May also want to set core to dynamic instead of auto, and set 20000 cycles.
Reply 68 of 112, by kstabell
once again I got the following after the splash screen:
sosDIGIInitDriver
C:\STTNG>_
Reply 69 of 112, by swaaye
Hmmmm this just doesn't make sense. You are using dosbox right? As in www.dosbox.com and not Windows's "dos box". The game definitely won't work with the plain Windows "dos" box (it's actually a horrible emulator).
EDIT:
Here's an archive of the setup I just put together to run the game. All you have to do is put your STTNG.ZIP file from the game CD into the STTNG folder. And then run DOSBOX.exe to get into the DOS window.
download
I left the cycles at 30,000. That may be too fast for your computer. If you get choppy sound, change the 30,000 setting inside dosbox.conf to auto,max or 20,000.
Reply 70 of 112, by kstabell
I'm using Dosbox 0.72, as for what you put up, I don't have enough instruction to know what to do with it exactly
PS. my HDD is C: and my CD drive is G:
Reply 71 of 112, by swaaye
Just unzip it to a folder. Inside is DOSBOX 0.72 along with a "hdd" folder, which is the folder that DOSBOX will mount as a virtual C drive. It will look like the only thing installed on C drive is STTNG. All you need to do is put your big STTNG.ZIP file from the game CD into the "STTNG" folder within that "hdd" folder. You don't have to do this inside DOSBOX.
Then just run DOSBOX.EXE and you'll get the Dos Box window.
type: "CD STTNG" and then "STTNG" to run the game.
Reply 72 of 112, by kstabell
and finally it works properly. now the question is, how to make it so it works properly without the specialized version of dos box you sent me
Reply 73 of 112, by swaaye
it's not really specialized. that's just how you set up dosbox to run a game. It's best to setup DOSBOX as a self-contained entity rather than mount your real system's C drive.
Reply 74 of 112, by kstabell
in that case should I transfer the other games to the version you sent me? also I noticed that with the modifications to the game it doesn't require the CD if I transfer the other games which also require a disc will I need to mount the drive still?
Reply 75 of 112, by swaaye
it's usually tricky to separate games from their need for their CD. You might need to edit a config file like the STTNG.INI. Or it may work just by copying all the files to the folder.
As for configuring DOSBOX, you should really head over to the DOSBOX site and read through the guides.
Reply 76 of 112, by kstabell
I have one (hopefuly) final problem, I can't save any games and I can't figure out how to fix the problem. I also can't restart the game without exiting back to dos.
Reply 77 of 112, by swaaye
Oh sorry... I guess you need to create a folder called "SAVEGAME" within the STTNG folder. Apparently the game's too dumb to make it on its own. 😀
Reply 78 of 112, by kstabell
Thanks, that solved both problems.
Reply 79 of 112, by V00D00
First of all: Please don't be mad at me, because I only registered to dig out this thread.
Secondly I want to appreciate the first post from swaaye, because it's the first instruction for running STAFU, that really worked stable and with sound!
But I wouldn't post here, if I weren't to dumb to get the thing working.
My problem starts (unsurprisingly) at the tactical screen, where the game just does nothing, except for the sound, which keeps on running. The game crashes, when I press the Esc key and displays DOS/32A warning (9003).
There is a FAQ which states the following:
Question #11:
I am getting these annoying warnings every time I run my program:
DOS/32A warning (9003): real mode interrupt vector had been modified: INT 00h
DOS/32A warning (9003): real mode interrupt vector had been modified: INT 22h
Can I disable them, and if yes, how?
Answer #11:
There are several ways to disable the warnings issued by the DOS Extender. One way is to add an option /QUIET to the DOS/32 Advanced environment variable DOS32A which is usually defined in your autoexec.bat file. This option will effectively disable all the warnings. Another option, /NOWARN:nnnn allows you to disable warning with a particular number, in this case 9003. Yet another way to disable warnings for only one application that uses DOS/32 Advanced DOS Extender is to use the SUNSYS Setup Utility program provided with the DOS Extender. Run the Setup Utility on the application you wish to reconfigure, press the F2-key, then 4-key and turn off the Report Modified Real Mode INTs option by pressing the ENTER key. Exit the Setup Utility program by selecting Apply Changes and Exit option (F10-key).
Anyway, I don't know how to use this piece of information...
But it looks like I'm so close to run this game without any errors!
The facts:
