First post, by WolperTing
Hello, some days ago I downloaded DOSBox 0.65 to get good ole
Settlers1 running on my XP - works great, even switching from
VGA to SVGA while playing the game doesn't cause any problem.
The only thing that behaves a bit strange is map scrolling in SVGA-mode:
It's accomplished by keeping the right mouse button pushed and then moving the mouse through the map. In VGA mode, that works fine,
the map "follows" the mouse. In SVGA, the map doesn't follow (it's frozen),
-- but when the right mouse button is released, the map suddenly jumps
to a new location. Has anybody else seen the same problem ? Thanks a lot !
