First post, by PooshhMao
Worked well in 0.63 (albeit slow), from 0.65 on, I can't get Stargunner running anymore.
Anybody here experience the same?
Reply 4 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Using the Plasma bomb at the beginning of the game gives me a Exit to error: IRET:Illegal descriptor type 0 (as soon as the bomb drops on "ground")
Does not happen with other weapons you can buy at start.
Normal and Dynamic core. 0.65.
GUS and Soundblaster.
Reinstall didn't help. Neither loadfix.
1+1=10
Reply 5 of 9, by PooshhMao
Doesn't crash here, using daum's CVS build... could you post your config?
I can't get the joystick working for longer than a couple of seconds though, I calibrate in the options menu, works, pretty much immediately afterwards the calibration is 'lost' and the controls go haywire. Keyboard or mouse control no issues.
Reply 6 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
For the joystick problem try the dosbox exe file from the Wing Commander III joystick thread. My dosbox.conf is the default except for cycles and core and autoexec.
1+1=10
