First post, by doublejo
Hello -
is it possible to emulate an usb mouse to the serial port ?! I'd like to play settlers 2 with the really great split screen mode. (I know I have to update the config file - but wasn't able to get any specific information about the configuration of the usb mouse to com1 itsself)
Thank you very much for your help!
-doublejo-
Reply 1 of 1, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Need serial mouse and Windows (if you don't have serial ports try a usb/com port adapter, but there is no 100% guarantee).
I just tested s2g, works with a serial (micros~1 😉 ) mouse.
Unfortunately dosbox spews out "write to reserved register" messages, maybe those should be removed in CVS.
1+1=10
