First post, by Eviladam
I have downloaded the latest version of dosbox
and when I try to startup blood and I get this
"Dos\4gw fatal error (1004): syntax is Dos4gw<executable.xxx>"
Reply 1 of 14, by franpa
did you run blood.exe in dosbox or dos4gw.exe?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 3 of 14, by franpa
so is problem fixed? if not then use blood.exe to play the game and setup.exe to setup the sound and resoloution etc.
my website
Reply 7 of 14, by franpa
make sure you setup the sound etc. before playing.... run setup.exe when in dosbox to set the sound.
my website
Reply 8 of 14, by Eviladam
Well I just fixed the problem by telling it the sound card is "none"
because my sound cards irq is freeking 19 and blood only goes high as 15
so I could play it but I only can listen to music as I play.
Reply 9 of 14, by DosFreak
huh? If your using XP then you use XP's emulated SB @ IRQ 5 or VDMSounds @ IRQ 7.
Make your games work offline
Reply 10 of 14, by franpa
try irq 5 and/or 1rq 7 for soundblaster 16 (a330 mpu-401 for music)
if it doesnt work post back...
my website
Reply 12 of 14, by DosFreak
DOS games in XP don't care what kind of sound card you have. For DOS games Windows XP emulates a SoundBlaster card. If you configure your DOS games to use any IRQ other than 5 then they will not work.
Reply 14 of 14, by franpa
to clarify... windows xp simulates an soundblaster for dosgames.
and dosbox emulates a soundblaster 16 for dosgames.
my website
