Iron Assault
First post, by cuttock
I found a game that was zipped into 2 folders.
One folder was labeled "IRON_CD".
I placed this in the emulated CD "D" drive and added the following to the Autoexec line in Dosbox:
mount d C:\Games\cd\ -t cdrom -label IRON_CD
And the other folder was labeled "games", which had another folder in it called "IRON".
This I placed in the "C" drive. I changed directory to this folder, and type
"Iron" to start the game, and the error message "cannot find MATH.DAT"
pops up. I found the file in the IRON_CD folder. But it seems there is a mounting issue.
I tried adding "-aspi or -ioctl or -usecd 0 flags in different combinations, but no go. Is there something wrong with the way I did this?
Reply 1 of 3, by SysGOD
you dont need to mount the IRON_CD folder as a cd-drive.
just copy it into your IRON folder.
AFTER you setup your soundcard and controller with the SETUP.EXE, open the IRON.CFG.
it looks like this:
SoundBlasterPro 220 5 1
Mouse
\GAMES\IRON
\IRON_CD
just change the last lines to match your settings.
for example:
C:\IRON
C:\IRON\IRON_CD
good luck 😉
Reply 2 of 3, by cuttock
That did it, SysGod! I wonder if this trick will work for some other games with similar Cd errors 😀
Thank you!
