First post, by hijacker
After some minutes playing civ I it crashes down.
When i try to build something in a city by clicking on the change button
the game halted.
i use dosbox 0.65 and stndart configuration.
could someone help me.
PS sorry for my bad english 😀
Reply 1 of 6, by PavelJ
i did'nt encounter the problem. i'm running v0.65 with normal core/10000 cycles 16mb ram. (yeah, overkill for civ1)
maybe you could try a different version of civ. my version is 475.01 . you can see your version in the blue box on startup where you select graphics/sound/input for civ. the important number is after the dot. before the dot it's always 475 or 474 but that just indicates distribution media and does not mean anything else.
good luck.
Reply 4 of 6, by PavelJ
i tried to locate a .04 version, but i just found an english .01 and a french .05. both work fine with normal and dynamic core. at least the 20 minutes i tested them.
do you use a cracked version without copy protection? maybe it's badly cracked.
