7th Guest
First post, by Eraser__
Hello,
I've been trying to start The 7th Guest in DosBox but without result.
The emulator crashes almost instantly after starting the game, writing to a log file "Exit to Error: CPU:GRP5:Illegal Call 7" if a normal CPU core was used, or "DynCor: Illegal option 0*ff" if the core was set to dynamic.
Tried this on both DosBox 0.65 and DOSBoxCVS, the problem persists.
Im using a P4-3GHz CPU, 512 RAM, Radeon 9600 video card, built-in AC'97 sound card. OS is WinXP SP2.
All other games work fine in DosBox.
Can anything be done about this, and what the heck do the error messages mean?
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
did you configure sound correctly ?
The messages mean that zero code was executed.
Water flows down the stream
Reply 3 of 3, by Mostro
http://www.home.earthlink.net/~infernofilecab … Guest_Setup.htm
Download the appropriate file from the website above and you can run 7th Guest in Windows. It crashes occasionally but save often and it's not a problem.
