First post, by RainaCharity
Hello All,
I just downloaded Life and Death (from Underdog) and everything seems to be working fine. Except for a "tiny" problem...Everything I successfully do is a failure, because for the life of me I can't figure out how to get my beeper out to look at the numbers I need to punch into the phone to return someone's call. I've pressed every key, yep I downloaded the manual but that part is missing. I don't know if anyone else has encountered this problem. I told you it was a dumb question 😜 I would like to thank you all in advance for any help you can provide...I've been searching forever for this answer. Thank you I do appreciate it.
Reply 1 of 1, by augnober
Perhaps the beeper is a copy protection scheme. The game may have shipped with a pamphlet with codes or whatever.. so rather than grab the beeper in the game, you're supposed to grab the real code list. That would explain why the information can't be found within the game and is inadequately described in the manual.
