First post, by augnober
Hi. I built dosbox in Ubuntu Linux (Dapper - 6.06) from the 0.65 sources and from the cvs sources. With standard settings, Xcom freezes going into a mission.
Before looking into it further, I'd like to know if this is a problem specific to a Linux build, etc.. Is everyone else seeing this problem upon entering a mission? What system/build are you running?
PS. I'm running with a 64-bit core. I first noticed the freeze using a 64-bit build. I then made a 32-bit build in a 32-bit chroot environment and got the same result.
PPS. I noticed there is no 'dynamic' core available in my builds. What is the reason for this?
Edit: I'm not 100% sure that I ran a 32-bit build, since I'm not very familiar with chroot and the 32-bit environment silliness. I'll try to make sure of it.
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
I ran into it myself.
Wd told my about the gus problem.
DOSBox crashes because the missionprogram suddenly starts playing soundblaster sounds. (while the game isn't setup for it).
Water flows down the stream
