First post, by Jo-Ga
Is there any way to install an additional driver like v24.sys, what normally is loaded in config.sys?
Jo-ga
Reply 2 of 3, by MiniMax
Rank Moderator
Moderator
V24?? That sounds suspiciously like a drive for a serial interface? I doubt it will work with the standard DOSBox. Maybe a special Windows build with direct serial control will work?
_________________
