First post, by Sanguinius
I am tring to run The Legend of Kyrandia 2 CD version. I mount a folder containing the CD files as a cdrom drive and another folder as my c: drive. I am installing the files from the 'cdrom' to the c: drive. This is successful. When I try to run the .exe file I get a message that states:
"A CD-ROM device driver is required to run Hand of Fate CD."
Does anyone know a resolution to this? Would be gretly appreciated.
Reply 4 of 9, by Sanguinius
Yeah, DOSBox 0.65 under Mac OS 10.4.7
The files are from an .iso that I made from the original cd
I copied the files in the .iso to a folder so I did't have to mount it everytime I want to play.
I am installing the game from the files that I got from the .iso to another folder that i am mounting as my c: drive
Reply 5 of 9, by LoneLines
Mount the ISO, that'll probably solve the problem (you can mount within DosBox and put it in the autoxec section of dosbox.conf for minimum hassle)
Also, I will check my CD of Kyrandia 2 and report asap 😉
EDIT: Took the HOF CD, made a BIN/CUE, mounted with Daemon, plays great with DosBOX 0.65 (xms, ems, umb = true, core=normal, cycles=auto).
LoneLines list of workarounds for various games in DOSBox:
http://ADogsBox.jellofishi.com
Reply 6 of 9, by Sanguinius
thanks for the update and thanks for giving it a try . . . ill have to give your suggestion a shot and try it with the .iso. 😀
I won't be able to test it for a bit as my cd is at my house, which I am not at currently.
Anything else I can try while I don't have the cd with me?
Reply 8 of 9, by MiniMax
Rank Moderator
Moderator
Please share your solution, Sanguinius.
_________________
Reply 9 of 9, by Stevecon
it looks like nobody has actually posted a solution to this problem so i will since im feeling charitable:)
its a different issue but its the same fix as kyrandia 1 cd. run with latest version of VDM sound:
(for noobies)
-you can install just in windows if you want, doesnt matter...
-goto the game folder, right click HOFCD.EXE and click run with VDMS
-you will get your error message, and a new VDL shortcut will be created in the same folder
-rightclick the new shortcut and goto properties
-check the box labelled "Enable low-level cd-rom support" and click ok
-Done, run that shortcut to play the game. Sounds/gfx/saving/everything works good, but the game seems to minimize if anything happens in the background (msn window blinks etc) thats not much of a problem, just really annoying.
hope this helps anyone with this problem.
