First post, by goat261
hi
i am new to this program (which looks to be great by the way) and dos as i always just used windows.
i used 'The Newbie's Pictorial Guide To DOSBox' guide which was very helpful but i get stuck on the part were it says
'Please consult the documentation of your game for which file is needed to start the game. In the case of Test Drive, it's TDCGA.EXE. So now, I just type this'
the file here is FIFADOS i believe but when i try to load it i get this message
DOS/4GW Protected Mode Run-time Version 1.97
Copyright (c) Rational Systems, Inc. 1990-1994
CD READ ERROR
any help at all would be much appreciated, if you need more information let me know as like i said im very new to these so not sure if ive posted all the information i need to for maybe someone to help me
Reply 1 of 19, by eL_PuSHeR
It seems program is attempting to access the CD-ROM drive. What mount commands did you use in DOSBox? Write down them here.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 19, by goat261
Z:\>mount C C:\oldgames
Drive C is mounted as local directory C:\oldgames\
Z:\>C:
C:\>cd FIF97
C:\FIFA97>FIFADOS
CD READ ERROR
thats as far as i got
Reply 3 of 19, by eL_PuSHeR
Your forgot to mount the CD-Drive.
If your CD is letter F: in Windows, you would add a second mount command...
Z:\mount d f:\ -t cdrom
MSCDEX installed
Drive F is mounted as CDRom
Z:\>C:
C:\>cd FIF97
C:\FIFA97>FIFADOS
Intel i7 5960X
8 GB DDR4 (2100)
Reply 5 of 19, by eL_PuSHeR
Try adding some more parameters. Maybe it needs a proper label. To check the label (volume name), go to My PC and copy the name of the CD.
E.g.
Z:\mount d e:\ -t cdrom -label FIFA97
Or try Input/Output control access mode too.
Z:\mount d e:\ -t cdrom -ioctl -label FIFA97
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 19, by goat261
thanks for help again mate. ive tried those but still getting same message, here are the 3 different ways ive tried.
MSCDEX installed
Drive e is mounted as CDRom
Z:\>C:
C:\>cd FIF97
C:\FIFA97>FIFADOS
CD READ ERROR
then i tried
Z:\mount d e:\ -t cdrom -label FIFAPCCD
MSCDEX installed
Z:\>C:
C:\>cd FIF97
C:\FIFA97>FIFADOS
CD READ ERROR
then
Z:\mount d e:\ -t cdrom -ioctl -label FIFAPCCD
MSCDEX installed
Z:\>C:
C:\>cd FIF97
C:\FIFA97>FIFADOS
CD READ ERROR
i still get the same error everytime so posting what i typed each time to see if i missed anything out, appreciate the help by the way
Reply 7 of 19, by eL_PuSHeR
Are you sure the CD is readable? Can you access it normally? Are you sure E: is the correct drive letter?
Intel i7 5960X
8 GB DDR4 (2100)
Reply 9 of 19, by eL_PuSHeR
Either the CD is badly damaged/scratched etc or your drive is broken. Can you test the CD on a different drive?
Intel i7 5960X
8 GB DDR4 (2100)
Reply 11 of 19, by eL_PuSHeR
Try cleaning the CD gently with a lint free moist cloth, in straight lines, from the center to the outer rim.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 14 of 19, by goat261
sorry for being stupid but how and when do i type that, im guessin its here
MSCDEX installed
eL_PuSHeR my new fifa arrived today and i still get the same message
could you please tell me were abouts in there i type usecd 1
Reply 15 of 19, by eL_PuSHeR
You must use it as another parameter:
Z:\mount d e:\ -t cdrom -ioctl -label FIFAPCCD -usecd 1
Intel i7 5960X
8 GB DDR4 (2100)
Reply 16 of 19, by rcblanke
2007-11-01 13:15 qbix79
* Emulate a trailing dot on volume labels of 8 characters when on a
cdrom drive. mscdex weirdness. Fixes Fifa96 cdrom detection.
...as well as Fifa97 cdrom detection! 😀
Reply 17 of 19, by theone
You should check the DosBox website for the list of versions of DosBox compatible with Fifa 97. If you are using version 0.72, it is not compatible with Fifa 97. There is a list of games. Click Fifa 97. You should see the compatible DosBox versions with Fifa97.You should be using version 0.70 which you can download from the website. Good Luck. 😀
Reply 18 of 19, by wd
Rank DOSBox Author
DOSBox Author
Compatibility list surely is no way to determine if a game does NOT run in
dosbox as that list is user-maintained and usually it just means nobody
tried it up to now/didn't commit the results.
Reply 19 of 19, by l_mcgregoruk
I tried Fifa 97 with dosbox before and it didn't work, then some time later I came back to look at the compatibility list, and it said FIFA 97 Supported Ver 0.70, so I assumed 0.72 would at least run it, which it didn't, so I got an unofficial build of 0.72 which did run it.
But I would of put Unsupported for Fifa 97 ver 0.72 in the compatibility list, except nobody can signup/login since hackers stole the account names/passwords, so the compatibility list surely IS a way to see if a game DOES not run in dosbox as it's never going to be updated by users if they can't update it. Unless there's somewhere else you can commit the results of games other than dosbox.com (Sourceforge?).
I've got quite a few old dos games I could test with 0.72(and later builds) and commit the results if I knew where.
