Terminator Skynet problem
Having problems with a specific game or application? Post your problems here!
Postby Speed_399 » 2007-1-13 @ 21:08
I searched for terminator skynet problems and I found a bunch of threads but no one contains my issue
I'm using DosBox 0.65 and D-Fend frontend
The problem is when I lauch the game it says:
Couldn't estabilish temporary directory.
Set the environment var. TEMP and try again.
(Ex: set TEMP=.\)
But I dunno how to solve this ... i tried to launch setting SKYNET.EXE -set TEMP=\. TEMP=G:\ and other tries and adding a TEMP= line in install.dat but nothing worked
what I have to do to solve this ?
ps. sorry for my english
Speed_399
Re: Terminator Skynet problem
Postby wd » 2007-1-13 @ 21:13
No, you got to type this before starting the game. Like this:
set TEMP=.\
skynet
wd
DOSBox Author
Postby Speed_399 » 2007-1-13 @ 21:16
moving it to C: and mounting C: instead of G: automatically solved it but I got sysinit problem now lol
thanks anyway
Speed_399
Postby Speed_399 » 2007-1-13 @ 21:23
ok solved that one too, I forgot to change G: to C: in install.dat :)
Speed_399
Postby Speed_399 » 2007-1-14 @ 12:40
it works now but it's way too slow and sound stutters are there any trick to solve this problem ?
Speed_399
Postby red_avatar » 2007-1-15 @ 20:16
a) get better CPU
b) wait for 0.66 which will see a major improvement
User avatar
red_avatar
Postby Speed_399 » 2007-1-15 @ 23:40
no chance changing cycles settings and other settings ?
btw i'm buying a conroe in theese days lol
thx for the help
Speed_399
Postby red_avatar » 2007-1-16 @ 19:13
With 0.65 even my Conroe E6600 can't run the game well. You really need 0.66.
User avatar
red_avatar
Postby maxxus » 2007-2-08 @ 09:39
boy do i hope that's true..
running skynet in 640x480 is like the holy grail of my dos experience. i've gotten system shock to run in high-res on xp i think ( dont ask me how) and all of my other goals, except skynet/future shock in 640. on my first pc it will run in 640, but it's too intensive for that pc to do right. i built up an old p2 with 256 megs of ram and a tnt2/voodoo 2 combo, 300mhz and it tries to put the refresh rate too high and puts my monitor to sleep :(
i guess i should be glad it runs without any sort of obscure crashing though *nods* i played through probably 80% of this game back in the mid 90's and i would so love to play it again. oddly, future shock and skynet are the only two games that gave me a genuine sense of vertigo when standing on a tall structure.
anyway, i will wait anxiously for .66.
User avatar
maxxus
Postby Neville » 2007-2-24 @ 20:47
Using the VGA mode, I've made my way up to level 4-5. I play it at 15,000 cycles and runs OK, if a tad slower than on a real PC.
User avatar
Neville
Postby CorvusMoore » 2007-8-15 @ 19:33
New member and didn't want to create a new topic when a few answers are present here.
I'm using 0.70 of Dosbox and trying to get SkyNET to work but its a complete no-go. I've looked through the Install document and made sure it matches to the directory mounted by dosbox but I get the error of "GAME, Error : SysInit (couldn't open archive) .
The most disturbing part is I do have the proper CD, but when I install the game through the auto-launcher and further promptings of the launcher, it never reads the game as installed. That includes the auto-launch program that gets installed in the game, it just dosen't seem to register itself as being on the system... when I try to run it without Dosbox about four lines come up on the window but it never goes any further, the No CD fix does nothing to help with this.
CorvusMoore
Postby Neville » 2007-8-15 @ 19:56
Try playing with the different ways of mounting a CD-ROM drive, my guess is that it doesn't recognise the CD.
User avatar
Neville
Postby wildweasel » 2007-8-15 @ 20:22
I had this error too, but I managed to fix it by manually editing the install.dat file in the game directory to point to the virtual directory instead of the real one. I spent a week trying to get past the SysInit error and only just today managed to figure that part out.
Anyway, after fixing the install.dat and configuring the sound, I was able to get most of the way through the first mission. Unfortunately, I can't get high-res mode to work without DOSBox crashing.
User avatar
wildweasel
Postby Neville » 2007-8-15 @ 22:20
The bad news are that CorvusMoore has already checked his INSTALL.DAT. The good news is that SkyNET's SVGA mode works fine since v0.71.
Image Image
Now seriously, I've had my share of troubles to get this game working, so my guesses are:
1) CD-ROM mounting. Have you tried all three methods?
2) The INSTALL.DAT file. Check it again, make sure everything is right, even the spelling and \ symbols.
3) Are you using any frontend? Frontends often mount games as C:\ by default, and that would contradict the settings in INSTALL.DAT even if you've placed the game on the right folder.
Let's imagine your game is in C:\DOSGAMES\SKYNET. Your mounting instruction shoul look like this:
MOUNT C C:\DOSGAMES
And your INSTALL.DAT should look like this:
[skynet]
installpath=c:\skynet
sourcepath=c:\skynet
type=net_large
Note that I'm running the cracked version, though.
User avatar
Neville
Postby CorvusMoore » 2007-8-15 @ 23:52
I'm not great with Dosbox, for me to get Blood working I just drag its EXE onto dosboxes EXE and they blend quite well. Same result with SkyNET always failed and its likely just an amatuer mistake I'm making when it comes to mounting.
But to confirm my Inst. for both entries is c:\skynet and thats the directory I mounted. Dos has always escaped me, the thing that really worries me though is how the game itself, both CD and the installed launcher don't detect the game, nor do the demo movies work, its quite worrying and yes it is the genuine article.
CorvusMoore
Postby MiniMax » 2007-8-16 @ 10:04
Amateur mistake - well.... When you drag the EXE onto DOSBox, the folder with the EXE becomes the C-drive in DOSBox. Then the EXE starts, looks in INSTALL.DAT and tries to find c:\skynet. But since the C-drive *is* (as far as anything that goes on inside DOSBox) in fact mapped to the EXE-folder (which is C:\skynet ??) the poor EXE is really looking inside c: + \skynet => C:\skynet + \skynet => C:\skynet\skynet on your real harddisk.
How much does it find there?
DOSBox 0.73 ReadMe | DOSBox Wiki | DOSBox 60 seconds guide | How to ask questions
_________________
Lenovo M58p | Core 2 Quad Q8400 @ 2.66 GHz | Radeon R7 240 | LG HL-DT-ST DVDRAM GH40N | Win 10 Pro
User avatar
MiniMax
Moderator
Location: Stockholm, Sweden, Europe, Earth Interests: Old games & young women
Postby SysGOD » 2007-8-16 @ 11:37
ah the lovely INSTALL.DAT problem again...
you can also put a "." behind every line in the install.dat, so that it looks like this for example:
[skynet]
fspath=.\shock
installpath=.
sourcepath=.
type=net_large
and you can copy or mount skynet wherever you want without touching this file again.
"fspath=" is only needed if you have future shock integrated with skynet.
User avatar
SysGOD
Postby CorvusMoore » 2007-8-16 @ 14:33
Still crashes but at least now it loads up, thanks a lot man, the "." solution for the inst worked perfectly.
CorvusMoore
Postby swaaye » 2008-2-15 @ 00:32
So playing Skynet in SVGA is a lost cause, as far as I can tell. No matter what, within a minute or two of gameplay, DOSBOX itself will crash. I don't think I've ever seen a command line after it crashes; it just takes DOSBOX with it.
What I've tried so far:
-Various versions of DOSBOX, including 0.72, CVS, and daum cafe
-ET4000 VGA mode (SVGA doesn't work at all with this)
-S3VBE TSR (VESA 2 extensions cause the game to not see SVGA support)
-Normal vs Dynamic core (nothing but slower-ness)
-Overlay and Surface display modes
-no sound
-game patch (1.01)
-dos32a
-large vs small install
-complete install (videos off CD and relative/absolute paths in install.dat)
---side note here: this seems to make SVGA crash immediately upon mission load. It draws half of the screen and then poof gone.
swaaye
Moderator
Postby wd » 2008-2-15 @ 07:21
What message?
wd
DOSBox Author
Next
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 3 guests
