First post, by Zippora
I keep getting the same error message when I try to start the 7th Guest in DOS and DOSBox. I switch to the game directory typing cd\id\t7g and then the prompt says ID\T7G(forward triangle). When I type t7g again, I get the error:'v' is not recognized as an internal or external command, operable program or batch file (see attached).Know how I can fix this?[
    13.52 KiB
Reply 1 of 4, by tannerstevo
The game works for me, both in dosbox 0.65 and the command prompt. Have you tried reinstalling the game? It may not have installed properly the first time.
Reply 4 of 4, by eL_PuSHeR
In ms-dos you can sweep clean (delete) the folder contents where it's installed.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
