Grand Theft Auto
First post, by elwis
Hi!
I'm trying to run my GTA under Gentoo Linux with DOSBOX 0.70
The problem is: Program says there aren't CD, but there is. I do "sudo mount /dev/hdc /mnt/cdrom" in xterm ( I have original CD) and then mount D: /mnt/cdrom -t cdrom in dosbox.
Has anybody Idea what could i do?
Reply 2 of 16, by elwis
It doesn't work. I make image with dd and load, everything ok but GTA still doesn't see it 😒
-----BEGIN GEEK CODE BLOCK-----
Version: 3.1
GIT d- s: a--- C++ P L++ E--- W+ N o-- K- w--- PS+
PE-- PGP- t X R+ tv- b+ DI- D+ G++ e-- h! r y+
------END GEEK CODE BLOCK------
Reply 3 of 16, by MiniMax
Rank Moderator
Moderator
So mr. L++
Would you please explain to us how you used dd to make a BIN/CUE image as DosFreak suggested?
_________________
Reply 4 of 16, by elwis
$dd if=/dev/hdc of=gta.iso
It's quite simple 😉
Version: 3.1
Reply 5 of 16, by wd
Rank DOSBox Author
DOSBox Author
That's no answer to the question.
Reply 6 of 16, by MiniMax
Rank Moderator
Moderator
It's quite simple 😉
Simple .... and wrong. dd can't make BIN/CUE images.
_________________
Reply 7 of 16, by elwis
it makes iso. anyway it should work, isn't it?
Version: 3.1
Reply 8 of 16, by wd
Rank DOSBox Author
DOSBox Author
Obviously not.
Reply 9 of 16, by elwis
So could you recomend me any program to make such images under linux?
Version: 3.1
Reply 10 of 16, by MiniMax
Rank Moderator
Moderator
http://linuxreviews.org/howtos/cdrecording/
_________________
Reply 11 of 16, by elwis
There is about conversion. Is there any point to do something like that? Anyway it doesn't work
Version: 3.1
Reply 12 of 16, by wd
Rank DOSBox Author
DOSBox Author
That section "3. Rip / Copy Multi-track Cd's (cue/bin)" looks like
direct ripping without conversion, did you try that?
Reply 13 of 16, by elwis
shit, I'm blind.
The one probem is how to make cue, it seems to be needed. When i mount bin there's no change. I tried use this toc as cue, but there were problems with mounting. Do you thing that bad condition of CD could be a reason of those problems?
Version: 3.1
Reply 14 of 16, by TLS_Vigra
I know this is an old thread... but hey.
GTA 1&2 are free, also check out 'GTA2 Game hunter'
Just one issue, I have a huge video problem, all I see is lines/static. Sound and frame rate is fine though.
Any tips?
