Dark Forces
First post, by Kicklighter
I got the following problem. I picked up my copy of Dark Forces and copyed i to my harddisk. Then opened Dosbox and entered the following syntax:
mount c d:\games\dark
c:\
subst p: c:\
c:\
cd dark
dark
Now this takes quite some woke so I downloaded the frontend D.O.G. but I can't configure it in D.O.G.
Anybody knows how it can be done?
Kind regards,
Paul
Reply 1 of 2, by DosFreak
Knows how what can be done?
Proper mounting procedure in DosBox?
Using unneeded commands in DosBox?
Unable to properly navigate the DOS command line?
Setting up and using DosBox with the CLI or setting up and using DosBox with a frontend like D.O.G.?
Make your games work offline
