First post, by Smiling Spectre
I have old compiled utility on old Borland language (Pascal, I think). It uses rtm.exe for work. Of course, it have "Error 200" on start - and old "divide by zero fix" works no more - I think, double core too much for it. So I decide to use Dosbox.
And I encounter strange problem. Under XP's cmd all work, when I slowing processor, without problems. But under DOSBox it isn't! It says "I want DPMI16BI.OVL!"
I found this file with new RTM, and problem was solved under DOSBox. But why DOSBox need this file, and Windows is not?
Reply 2 of 6, by Smiling Spectre
I don't good with all this dpmi (I even don't know, what it is exactly). Can you elaborate little more: is it means, that any windows have dpmi support somewhere inside, and this file not needed there?
Reply 4 of 6, by Smiling Spectre
I predict this suggestion, so don't ask "what is dpmi" or "how it works". 😀 I ask only question, that could be answered with "yes" or "no". Not? Ok, then google. 😀 Thank you anyway for your answers!
Reply 6 of 6, by Smiling Spectre
You force me to read about DPMI to avoid shame for myself. 😀 Ok, now I know, that protected mode not appears by itself, but must be supported by embedded or external host. 😀
Thank you, really, that you force me to know it. 😀
