First post, by Darian
Hello,
I have Wing Commander 3 runing in DosBox 0.72 on a linux (Ubuntu 7.04) System. Everything works fine. Program starts with cd mountet using
mount d /media/cdrom0 -t cdrom
or with mounting a directory containig the cd content (a linux-mounted cd-image in my case).
A Problem appears, when the game wants me to change the cd. After changing the cd the program still persists on "wrong CD, please insert cd 2". The same appears with mountet images.
Adding the -usecd 0 and the -ioctl options did not help.
Where is the problem. Does anyone know a solution?
Thanks
Darian
