Installing Jungle Strike from CD-ROM
First post, by Crowley
I can install the CD-ROM version of Jungle Strike fine, but only if I choose not to play video sequences in the game. If I want that, the installation program says it's checking the speed of my CD-drive. Then it just stays there and nothing happens. I am using a CD-image, which I have tried both by mounting it with Daemon Tools and mounting the virtual drive in Dosbox, and I have also tried mounting it directly with imgmount. Both ways bring up the same problems.
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
Exactly HOW do you mount the CD and/or the image? EXACTLY!
_________________
Reply 3 of 8, by MiniMax
Rank Moderator
Moderator
And this is with DOSBox 0-72? On which operating system?
_________________
Reply 5 of 8, by jamyskis
I'd like to necro this thread (as opposed to pointlessly starting a new one) as I have precisely the same problem. I have the Desert Strike/Jungle Strike CD-ROM. Desert Strike works without any complaints. Jungle Strike on the other hand locks up with the message "Checking speed of CDROM drive. Please wait..." when I try to install with video sequences.
I'm using 0.74 on Win7 64-bit, I've tried it directly from the CD with normal access, IOCTL access, and low-level SDL access (-ionoctl), I've also tried making an ISO from the CD through D-Fend Reloaded and tried mounting it from there.
I'm at a loss here.
Ryzen 5 3600 @ 4.2GHz per core
16GB RAM DDR4
AMD RX 580
6TB hard drive over three hard drives
Windows 10 Pro
Reply 6 of 8, by jamyskis
Never mind, I've just found a workaround:
* Install Jungle Strike and press "N" when asked if you want video sequences. The installer will then avoid the CD-ROM speed check.
* Open up the Jungle Strike folder on your hard drive.
* Open the file JUNGLE.BAT in Notepad.
Then change
@D:\JUNGLE HD %1 %2 X
into
@D:\JUNGLE CD %1 %2 X
That'll do the trick.
16GB RAM DDR4
AMD RX 580
Windows 10 Pro
Reply 7 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Actually, there is no "CD" parameter, and invalid parameters make the game use its defaults (non-full install, normal movies), which is equivalent to changing the line in the batch file to just "@D:\JUNGLE". The "HD" parameter tells the game to look for its .DAT file on the hard disk, and corresponds to the "full install" option.
The last parameter is the movie option:
X = None (slideshow)
Q = Small (320x200, quarter size)
V = Normal (320x200, slightly letterboxed)
S = Large (640x480, scanlines, more letterboxed)
It seems to me that the "S" movie option doesn't display more detail than the "V" option, it's just a different presentation that ostensibly needs more CPU.
Reply 8 of 8, by Alexis78
jamyskis wrote on 2012-07-19, 12:28:
Never mind, I've just found a workaround: […]
Then change
into
That´s It man! Oh, Thank you very much, It did the trick, now I can use D-Fend Reloaded and play the CD version of Junlge strike directly without going to the Dos prompt before as I used to do.
