Problem with WYSIWYG in Lotus 123 2.4
First post, by Andy73
Hello,
I have a graphical problem with using the WYSIWIG-mode in Lotus 123 V2.4. When I switch into the WYSIWYG-mode from the normal mode then colours get inverse (backround from black to white) and the cells seems to be empty. Working isn'n possible then.
I hope sombody can help me with this problem. Sry for my bad english... I hope you can imagine what's the problem.
Thanks
Andy
Reply 6 of 6, by jd-angel
I found a way to remedy it. This solution must be set every time, since the configuration is cancelled when leaving the program.
1) Enter WYSIWYG mode (":" key)
2) Go to Display-> Options-> Adapter-> Blink-> Yes
3) Go to Display-> Options-> Adapter-> Blink-> No
4) Go to Display-> Options-> Adapter-> 1 (VGA)
Probably, a macro that loads at the beginning will fix it.
