Hey guys,
I' ve got the solution !!!
The videos (ALL VIDEOS :-DDD) work ONLY in Dosbox 0.63 !!
I really don't know why. I' ve set up dosbox 0.65 and above with EXACTLY the same parameters in the configfile, but videos (exept the ones mentioned above) are screwed up.
This is what I used:
frameskip=1
aspect=false
scaler=none
core=dynamic
cycles=38000
cycleup=31600
cycledown=31600
(This is because the menu required less cycles while the racing required more).
I mounted my CD-ROM drive as follows:
mount F "F:\" -t cdrom -usecd 1
(Notice that on your machine the "-usecd" option might require another number, refert to the dosbox readme file for further information)
Unfortunately, dosbox 0.63 doesn't support images as good as newer versions, which means that you have to use a read disc.
Greets,
Mike
