First post, by Starmanw432008
Hey Friends, My name is Steven Whitehouse, and this is my first post on this site. I'm have problems with getting Starflight 1 and 2 to run in FULL SCREEN MODE. My friends at http://icc.starflight3.org/index.php has tried to help me out with this problem. I've tried every suggestions they gave me like clicking ALT+ENTER. And tried changing the requirements in the game itself. But everything I've tried failed. So I had to return everything back to normal 🤣. My question is this, Is there anything I missing to get Starflight 1 & 2 to run on vista windows? I know I can slow it down with Dosbox. Right now, I just want to play both games 🤣. So I can get use to the Starmaps so I can be ready to play Starflight 3 "Mysteries Of The Universe". And howdie to all my fellow starflight friends that are here too, THIS IS CAPTAIN THRYSS_THRYNN2006 OF ICC FORUM If you wanted to say howdie!
Captain Thryss_Thrynn2006 Out(Steven Whitehouse)
😢 Reason why I'm depressed is my favorite cat just died.[/url]
Reply 1 of 3, by DosFreak
So this issue is that when you run the game in DosBox in Windows that DosBox isn't fullscreen?
When you mean you "click ALT+ENTER" did you mean that you held down the ALT key and pressed the ENTER key?
You can also try setting fullscreen= in dosbox.conf
Make your games work offline
Reply 2 of 3, by MiniMax
Rank Moderator
Moderator
Can you run DOSBox all by itself in full-screen mode?
_________________
