Zombieville
First post, by zelenog
I am trying to install a DOS game called Zombieville.
But I get the error message "Not enough space on drive C." But I have 100 GB free!
Can someone help me get the game running?
Reply 3 of 27, by zelenog
I have another problem.
The intro of the game seems to be running too fast, and at the end when the game is about to start, it freezes, and nothing happens.
I hit ctrl F 11 to slow the speed down, but to no vail.
I am using DosBox 0.70
Any suggestions?
PS. The game is bugged as hell. But there's no patch, and the game is supposed to begin anyway. The bugs only affect the game later on.
Reply 10 of 27, by zelenog
when I typed "loadfix" it told me that '64 kb allocated'
However, it didn't help as the game freezes again.
What's strange is that the intro of the game runs insanely fast (and there's no music). Could it have something to do with the game freezing?
When I installed the game, I did configure sound and digital audio (soundblaster 100% compatibles & ultra gravis something, respectively)
what else can I try?
Reply 12 of 27, by zelenog
I already installed the game to my drive C (in a folder called Zomb)
So, to get the game started I first mount the drive where my CD is located (drive g) by typing the following command : mount d g:\ -t cdrom
Then I mount the folder where my game is located. I.e. "mount c c:\zomb\zomb"
Then I do this :
c:
dir\
there I find zville.bat So, I type "zville.bat"
And the intro of the game begins, but when the intro comes to an end and when the game should begin, it just freezes.
Am I doing smth wrong?
Reply 15 of 27, by wd
Rank DOSBox Author
DOSBox Author
What i mean is
a) start dosbox
b) mount the hd and cdrom in some sensible way
c) install the game
d) play the game
e) exit dosbox
Note that exiting dosbox is ONLY done as last step. When you replay the
game, use the EXACTLY same mounting as in step b)
Reply 18 of 27, by wd
Rank DOSBox Author
DOSBox Author
As i said use the CORRECT mounting. The game installs by default into the
zomb subdirectory, so to start the game you HAVE to change the directory.
You posted you don't have to, so you either installed it into a different
directory (wrong) or you didn't installed it inside dosbox (wrong). I surely
won't respond any longer if you're not sticking to the exact wording of
MiniMax's guide.
Reply 19 of 27, by MiniMax
Rank Moderator
Moderator
I suggest you read my guide again. And read it out loud in a quiet room.
_________________
