Reply 20 of 26, by wd
Sad enough some people are too stupid to understand mounting and recommend
to mount their whole harddisk, and then go putting it into a tutorial...
Boy, you sure provide constructive feedback.
However, I adjusted the tutorial accordingly.
aL
Well it's typed out in explicit letters that you should not do it, can't be more constructive.
Still has the same mounting line there (+warning), but thanks for trying.
luckily those mountings won't work 😉
The XBCD version referenced in that guide is not the latest one, either. http://redcl0ud.1.forumer.com/index.php?showtopic=1816&st=0#
Okay, I linked XBCD 0.2.6 as well.
The mounting does indeed work for me (in 0.72) and game would not run without it, but I guess that's just because I did not install the game in DOSBox.
aL
wrote:but I guess that's just because I did not install the game in DOSBox.
Which is preferred to do. 😉
Klimawandel.
