Mouse Y-axis reverse?
Having problems with a specific game or application? Post your problems here!
Postby Sheriff Hobbes » 2009-4-23 @ 20:40
Hi!
You all know the problem: You have a game installed and you figure out that it doesn't give you the option to reverse the mouse y-axis. Especially an FPS will make that unplayable for you. Just happened with Dark Rites. Default is mouse up for looking down, but I can only play vice versa.
Is there a mouse tool around which solves that problem?
Sheriff Hobbes
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
User avatar
Sheriff Hobbes
Re: Mouse Y-axis reverse?
Postby wd » 2009-4-27 @ 10:21
There's currently no way to change this besides messing with the sources.
Maybe somewhen the mouse movement/buttons will be included in the
mapper so they can be arbitrarily changed.
wd
DOSBox Author
Postby tikbalang » 2009-4-27 @ 12:15
there is hacked version of ctmouse.exe that deals with this problem. i'll try to look for it. i don't know if it will work with dosbox though.
ESS PCI DOS Drivers
_________________
User avatar
tikbalang
Postby ErikGG » 2009-4-27 @ 14:52
I tried to add it to D.O.G by hooking into the Mouse LowLevel System Hook of Windows, and it worked as long as it wasn't DirectX or OpenGL that was rendering.
So the only two options I geuss there are left are rewriting a plugin dll for SDL or rewriting DosBox.
User avatar
ErikGG
Postby Sheriff Hobbes » 2009-4-27 @ 19:19
I think a good solution would only be inside DOSBox, because
a) portability - go with your game config to any computer and it will work
b) it's probably not so good tampering with your Windows drivers. It may work on a Windows XP, but not on Vista, etc.
If anybody of you DOSBox guys could do that, it'll be perfect. I'd like to help, but I'm not a programmer. :(
-engagement ring
-wedding ring
-suffering
H. L. Mencken
User avatar
Sheriff Hobbes
Postby wd » 2009-4-27 @ 19:36
It won't be any time soon, sorry.
wd
DOSBox Author
Postby tikbalang » 2009-5-06 @ 10:06
here it is: ctmouse v2.1b4 including binaries with inverted axis.
ctm21b4x.zip
ctmouse v2.1b4 with inverted axis.
(295.88 KiB) Downloaded 1832 times
ESS PCI DOS Drivers
_________________
User avatar
tikbalang
Postby Sheriff Hobbes » 2009-5-06 @ 19:14
Thanks a lot! Tested it with Last Rites - works great! :)
-engagement ring
-wedding ring
-suffering
H. L. Mencken
User avatar
Sheriff Hobbes
Postby pycur » 2019-8-09 @ 09:50
Sheriff Hobbes: I today found this game, and I also used ctmouseY.exe to invert the mouse axis in game, after that I hit Ctrl F5 to take some screens, and the game noticed me to changed mouse axis by itself without the tool...so F5 is simply changes axis in the game... :D
pycur
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 2 guests
