usnf dosbox ?s
First post, by Allenm100
My dos box wont open usnf i keep getting a message that says cant run usnf.exe?
Reply 1 of 10, by wd
Rank DOSBox Author
DOSBox Author
Works fine here.
Reply 2 of 10, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 10, by Allenm100
come on guys any suggestions? 🙄
Reply 4 of 10, by Tsyu
Type dir /w in the game directory (within DOSBox). Do you see usnf.exe? If you do, what is the exact error you get when you try to run the game?
Reply 5 of 10, by wd
Rank DOSBox Author
DOSBox Author
You gave absolutely NO useful information so you won't get any useful suggestions.
Reply 6 of 10, by Allenm100
In the c:\dir i see usnf.exe so when I tpye c:\usnf it start to procces and I get a message that says Loadfile can't load usnf?
I have a toshiba laptop xp with intergatedgraphics,cleron m,60g 1000m and thats about all the spec I can think of,
When I try to run it from MS-dos Iget an eror that says Memory Protection Valt,01a7H00000013h?
I jnow i'm just a noodb, but this old school game is really cool!
Reply 7 of 10, by wd
Rank DOSBox Author
DOSBox Author
dosbox version?
How did you install the game, and how exactly do your mounting lines look like?
Reply 8 of 10, by Allenm100
When I try to install the game from d:\install the install program says tha I have to run it from the cd-om,,,I think I just need help getting the cdrom to mount fully
Reply 9 of 10, by Allenm100
v.72
Reply 10 of 10, by wd
Rank DOSBox Author
DOSBox Author
Check the readme and the guide threads on the guide forum.
You need the -t cdrom parameter when mounting the cd drive.
v.72
Maybe upgrade then.
