Soccer Kid CDRom > problem with music Tracks
Having problems with a specific game or application? Post your problems here!
Postby redgriffith » 2009-5-31 @ 02:20
Hello,
I have problems with the music tracks of "Soccer Kid" the Cdrom version.
I explain:
First i'll try The floopy version and it works very well music and sound FX. (It's need EMS=False for information)
->I'll buy Recently the Cdrom Version, and impossible to have the music ! For information the music are on audio tracks. It's obvious because on title screen the music seem to start and one second after it's blocking and repeat infinitely. I push the start button and when the first stage begin, this time it's simply, there is no music...
i have tried all i can do: -noitcl and -itcl, iso files, tried on two PC...i don't know what to do now...
I am on windows XP and use DFEND_v2 and DOSBox-0.70
Thanks in advance if someone can help me! :depressed:
User avatar
redgriffith
Re: Soccer Kid CDRom > problem with music Tracks
Postby Tsyu » 2009-5-31 @ 07:27
Both D-Fend and DOSBox 0.70 are old. Use DOSBox 0.73 instead.
Also, are you able to play the music in Windows Media Player (or another audio player)?
Tsyu
Postby redgriffith » 2009-5-31 @ 11:34
Thanks for you reply.
Yes i can read the audio tracks with windows media player and all works OK.
I saw That In the game, the track for the first stage begin and stop after 2 Sec like the title screen ...
I have just tried with d-fend reloaed and dosbox 0.73, it's seem to be the same :( .
I made an iso of the game that you can download here : http://LINK-DELETED
thanks
User avatar
redgriffith
Postby MiniMax » 2009-5-31 @ 12:43
Unless you can provide a good source that says this game is legal to download, we don't like you to use this place as a way of distributing unlicensed games.
I suggest you try the free version here, which should work nicely on new versions of Windows:
http://www.brothersoft.com/soccer-kid-167583.html
DOSBox 0.73 ReadMe | DOSBox Wiki | DOSBox 60 seconds guide | How to ask questions
_________________
Lenovo M58p | Core 2 Quad Q8400 @ 2.66 GHz | Radeon R7 240 | LG HL-DT-ST DVDRAM GH40N | Win 10 Pro
User avatar
MiniMax
Moderator
Location: Stockholm, Sweden, Europe, Earth Interests: Old games & young women
Postby redgriffith » 2009-5-31 @ 16:40
The PC version is an abandonware : here, you can download it (but it's the floppy version and it works well...):
The Cdrom version is the Same. The difference is just the music are on audio tracks...It's not OK ?
Thanks
User avatar
redgriffith
Postby Qbix » 2009-5-31 @ 16:42
abandonware is not okay. it is an invented term to be indicate that the developer might not care anymore. Still it is illegal
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby redgriffith » 2009-5-31 @ 17:05
So ok...I just wanted to solve the problem.
I still don't understand why the audio tracks stop like that.
This kind of problem was already met with other games ?
User avatar
redgriffith
Postby MiniMax » 2009-5-31 @ 18:41
I don't know what is causing this problem, but until someone proves otherwise I will say it is a problem caused by whoever created the download copy. If it is so, then it is not a problem with DOSBox, and trying to solve it will be .... a waste of time. Get a legit copy, and if the problem still is there, then it will be worth investigating.
_________________
User avatar
MiniMax
Moderator
Postby redgriffith » 2009-5-31 @ 19:02
I have the Legal Copy, i bought this rare game recently (on ebay).
So I tried first with the Cdrom, without sucess. I tried to made an iso and it's the same...
User avatar
redgriffith
Postby redgriffith » 2009-5-31 @ 19:09
DosFreak wrote:ISO's don't contain CD Audio....
I made A bin/Cue image file in order to have audio tracks. Like The cdrom the music begin and stop after 2sec or repeat infinitely.
User avatar
redgriffith
Postby MiniMax » 2009-5-31 @ 19:09
I am no expert on this music track business, but instead of ISO-images, try what they (the experts) call a BIN/CUE image.
_________________
User avatar
MiniMax
Moderator
Postby redgriffith » 2009-5-31 @ 19:12
MiniMax wrote:I am no expert on this music track business, but instead of ISO-images, try what they (the experts) call a BIN/CUE image.
yes, i knew it. When i say "iso" i think "image file" :blush: (my image file was a Bin/cue)
User avatar
redgriffith
Postby wd » 2009-5-31 @ 19:31
exact mounting line?
wd
DOSBox Author
Postby redgriffith » 2009-5-31 @ 19:55
OK. I used D-Fend V2 and D-Fend reloaded... Here is the first configuration i had tried:
[sdl]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=false
sensitivity=100
waitonerror=true
usecancodes=true
priority=higher,normal
mapperfile=mapper.txt
[dosbox]
language=
machine=vga
captures=C:\Program Files\DFEND_v2\Capture
memsize=16
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=normal
cycles=3000
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
device=default
config=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=1
dma2=1
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=22050
tandyrate=22050
disney=true
[dos]
xms=true
ems=true
umb=false
[bios]
joysticktype=none
[autoexec]
mount C "C:\"
mount D "D:\" -t cdrom
D:
cd\
cd
INSTALL.EXE
(I had already tried
mount D "D:\" -t cdrom -ioctl
mount D "D:\" -t cdrom -noioctl
User avatar
redgriffith
Postby wd » 2009-5-31 @ 19:59
Please stick to dosbox 0.73 along with dfend reloaded if you really really
have to use a frontend. Then start off with a CLEAN dosbox config file
and don't use any old one.
wd
DOSBox Author
Postby redgriffith » 2009-5-31 @ 20:21
Ok so this one is my configuration with D-Fend reloaded 0.7 and Dos-box 0.73 :
(delete)
User avatar
redgriffith
Postby wd » 2009-5-31 @ 21:14
This is an invalid config file for 0.73, please start with a CLEAN one from
the official 0.73 installation.
wd
DOSBox Author
Postby redgriffith » 2009-6-01 @ 00:28
wd wrote:This is an invalid config file for 0.73, please start with a CLEAN one from
Ok i restarted from the beginning with only Dos Box 0.73 !
i generated the dosbox.conf (see attached file), and i put in the autoexec:
[autoexec]
mount C "C:"
mount D "D:" -t cdrom
D:
cd\
cd
INSTALL.EXE
I start dosbox
The game install
i run Go.bat, the game start, speed, graphic and sound fx are OK , the music still bugging :s-face:
dosbox.conf
(9.93 KiB) Downloaded 140 times
User avatar
redgriffith
Postby wd » 2009-6-01 @ 10:01
config file looks fine now, yeah :) I assume this actually is the file that is
loaded by dosbox (check the status window if you're unsure).
I thought you were using a cue/bin pair, what happened to that?
Anyways, for your current mounting try different parameters like
"-t cdrom -ioctl_dx" (check the readme).
wd
DOSBox Author
Next
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 2 guests
