First post, by codone
Hi all, I wanted to mention my experience tonight with the new 0.73 DosBox. After my upgrade from 0.72 (and trying with the old java DosBox Game Launcher , and the new .65 which supports the new 0.73 Dosbox). I've run into a problem running the old robot RTS called "Z".
"Z" has always run fine with a few previous versions of Dosbox, but with 0.73, when I hit "NEW GAME" (in the Z menu) it goes black and locks up, and eventually exits back to windows. Strangely, it allowed me to load a saved game, and seemed to work fine -- only "NEW GAME" has the problem.
I load Dosbox 0.72 and it again works fine on "NEW GAME".
I am using files copied from the original CD that I own, I mount a C drive for the installed files, and a CD image for the CD. Again, it all has worked fine for years of on and off play for at least 2-3 previous versions of Dosbox.
I'd give more info, but I'm not sure that would help much as the mounted drives all work fine, the game loads fine, and it works fine with 0.72. Again, I tried using the older version of DBGL loader, then I got the latest version 0.65 which supports Dosbox 0.73, and it did the exact same thing. I even tried slowing down the CPU rate... same problem.
Anyone else seeing this problem with "Z" ??? I am running it in SVGA mode (selected in-game from the main menu) and movies OFF.
