CD-protect
First post, by ChaosFish
Hello,
First of all I'd like to thank you for making such a wonderful program like DOSBox! Thank you!
I tried to run Rayman, and it doesn't recognize the CD as the original CD, although it is (mount D works, but it doesn't recognize it the cd protection on it).
Is there anything to do?
Reply 3 of 4, by McEck
hi,
i had a similar problem with battle isle 2. download one of the latest csv-builds (files.pixelz.org for example), that should fix it. maybe you also have to mount your cd-drive like this:
mount d g:\ -t cdrom -usecd 0 -ioctl
someone mentioned the ioctl-switch has no effect when used with the usecd. well, i don't know, didn't try it. hope that helps.
greetz
Reply 4 of 4, by Nicht Sehr Gut
Originally posted by ChaosFish Although it still thinks it's not the original CD... has anyone experience Rayman on DOSBox?
Be aware that there is more than one version of the original game (and I don't just mean re-releases...I mean the code is actually different).
