CVS - Sound fx in Gabriel Knight I
Having problems with a specific game or application? Post your problems here!
Postby MadEgg » 2003-9-28 @ 21:50
I retried it with the latest CVS-version and the performance is a whole lot better than I experienced before, it's now really playable.
But I can't seem to get the Sound Effects/Voices to work. Every time I select one of the sound effects devices the game crashes with a message about some error in audio.cpp.
Has anyone tried it/got it to work? If so, how? Or is this just a problem of the so far limited real mode support and should I just wait for new releases?
Eyyyy
MadEgg
Re: CVS - Sound fx in Gabriel Knight I
Postby Nicht Sehr Gut » 2003-9-29 @ 02:45
Originally posted by MadEgg [B]Or is this just a problem of the so far limited real mode support
Actually real-mode support is fine, it's protected-mode that still needs a lot of work...and "GK" uses protected mode...[B]
...and should I just wait for new releases?
Wait or try the Windows version (being sure to only save while the map is onscreen).
User avatar
Nicht Sehr Gut
Postby MadEgg » 2003-9-30 @ 11:43
Yes sorry, I meant protected mode of course.
I don't have any Windows on any of my boxes so I'll have to wait; but does it actually work in Windows' dosbox?
And what about the map? It corrupts when you save it outside the map? So that means you can't save at the part in Germany and further?
I'll just wait some more then :p
Eyyyy
MadEgg
Postby Nicht Sehr Gut » 2003-9-30 @ 21:34
Originally posted by MadEgg [B]I don't have any Windows on any of my boxes so I'll have to wait; but does it actually work in Windows' dosbox?
In 2000 or XP, it can only load or save when the map is displayed.
It should work if run within Win3.1 or Win9x.
User avatar
Nicht Sehr Gut
Postby MadEgg » 2003-9-30 @ 22:03
Ow, you meant running the Windows version of GK1? I've tried that a couple of months back on a Windows 98 machine, no luck there.
Game ran fine, but without sound and music. So not an option for me. That was on a Creative Soundblaster 16, which is supposed to be compatible with the game.
It also ran on that exact same machine when I put another harddrive in with only DOS 6.22 on it. But I hate swapping harddrives :mad:
Eyyyy
MadEgg
Postby Nicht Sehr Gut » 2003-9-30 @ 22:51
Originally posted by MadEgg [B]Ow, you meant running the Windows version of GK1?
I was. [B]
Results vary...
User avatar
Nicht Sehr Gut
Postby Nicht Sehr Gut » 2003-11-15 @ 02:49
I split off the posts about running GK in Windows ME into a separate thread here.
User avatar
Nicht Sehr Gut
Postby Dark Knight ez » 2003-11-16 @ 15:10
no offense, but this post is better...
it gets GK1 running flawlessly, dos-version using dosbox.
http://www.vogons.org/showthread.php?s=&threadid=2729
Dark Knight ez
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 4 guests
