Reply 20 of 34, by robertmo
- l33t++
general midi is just a standard of writing notes and it is up to you what synthesizer you connect to it. You can even connect an FM synthesizer to it.
if you want to compare, compare with SCC which is the first Roland synthesizer compatible with General Standard (that includes General MIDI)
http://www.crossfire-designs.de/index.php?lan … dcards/&page=13
You can also compare with GUS, yamaha XG or roland lapc
also gus is emulated in dosbox, lapc is in gulikoza's build.
you can install any software synthesizer, or buy a real device
you can use timidity and load just any soundfonts you want
you can have a sound card that allows loading sound fonts
awe32 also could be expanded with memory and allowed loading soundfonts but it was limited to 20MB soundfongs.
by the way scc and awe sound fonts were about 3mb i think or even less
Right now i can load even almost 300MB (haven't found any larger) soundfonts in timidity
you can do whatever you want
