First post, by Gadget2006
Hello,
I'm having an issue with the first table of the Silverball game (the table is called "Fantasy") - after a certain period of time, the game would go into slow motion, the sound would turn off, and the controls would become irresponsive, and the only way to make the game work again would be restart DOSBox.
While it seems like a long-standing known issue with the game (I've found a compat report dating back to 0.6x series with the same problem), I have only found one suggestion of a possible solution (lowering the number of cycles, possibly to 7000, and trying to set core to normal) which does not do anything, the game still hangs the same way (maybe subjectively a little less frequently, but it's debatable).
Is there anything else that is possible to try to do to fix this issue or is the table/game simply not yet compatible enough with DOSBox and nothing could be done? Thank you very much for any advice.
