First post, by Shagittarius
So I've been messing around with Prophecy of the Shadow and I can't get it to run with MT32 for music. I've tried uart and intelligent mode but the same thing happens for each; the screen goes blank after starting the game and freezes. I watch my MT32 but no communication is taking place with the game in either mode.
I'm using a real brand new (was sealed till I opened it) copy of the game. Does anyone know anything about this title and the MT32?
Reply 1 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
In the QUEST.TXT file included with the game there is this note: "Added support for SB/SBpro at non regular address." There is in fact a mechanism in the game's code to switch between base ports of 220 and 240 for the SB, but it was also made to apply to the MT-32 music configuration, which looks like a bug. The MIDI base port should be 300, 310, 320, or 330 (DOSBox has it at 330), and the game hangs trying to interact with the MPU-401 on ports 220 and 221.
A brief search turned up no patches for the game; but there is a way to get the MT-32 music working if you don't mind a little hex editing: at offset 43C in MT32MPU.ADV change bytes 8B 46 06 to B8 30 03.
Reply 5 of 5, by Stiletto
MagikGimp wrote:
I also can't believe I've never had a Vogons account until now. Been visiting this site for centuries... 😒
*dopeslap upside the head* welcome! 🤣
do the Fandango!" - Queen
Stiletto
