First post, by reble1950
The original file on the desktop computer were dosbox is on the c hard drive and the games is on the e hard drive works just fine.
c:\dosbox\dosbox.exe -c "cycles 9010" -c "mount c c:\dosbox" -c "mount e e:\games\dos-games" -c "e:" -c "cd bstone" -c "bs_aog.exe powerball radar"
i am trying to adapt the bat for the laptop were the dosbox and the game are on the same hard drive but in difrent directorys. the changes i made aren't working. what am i doing wrong.
c:\dosbox\dosbox.exe -c "cycles 9010" -c "mount c c:\dosbox" -c c: cd\games\dgames\bstone -c "bs_aog.exe powerball radar"
steve
Reply 1 of 15, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
c:\dosbox\dosbox.exe -c "cycles 9010" -c "mount c c:\dosbox" -c "c:" -c "cd games\dgames\bstone" -c "bs_aog.exe powerball radar"
(assuming you have that game in the real path on your laptop in c:\dosbox\games\dgames\bstone)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 15, by reble1950
the dosbox prog is in the c:\dosbox directory
the game is in c:\games\dgames\bstone directory
Reply 4 of 15, by reble1950
how should the line read
Reply 6 of 15, by reble1950
you think, i have been thinking for 3 days wsithout solving the problem. why do you think i came here
Reply 7 of 15, by reble1950
would someone please just tell me strate out how to fix the line. this is my 4th day of trying to fix this problem. and it isn't fixed jet.
Reply 8 of 15, by wd
Rank DOSBox Author
DOSBox Author
What does it look like after you thought/modified what Dominus posted?
Reply 9 of 15, by huglester
Hello
what about?
c:\dosbox\dosbox.exe -c "cycles 9010" -c "mount c c:\games" -c c: -c "cd dgames\bstone" -c "bs_aog.exe powerball radar"
Reply 10 of 15, by ripa
Your bat will work if you use use the line Dominus posted and put the game in c:\dosbox\games\dgames\bstone
Reply 11 of 15, by SKARDAVNELNATE
Please explain why you want DOSBox to mount itself.
Also, why assign the game to drive E instead of C?
Reply 12 of 15, by reble1950
The original file is on the desktop computer were dosbox is on the c hard drive and the games is on the e hard drive works just great.
i am trying to adapt the bat for the laptop were there is only 1 hard drive. the dosbox prog and the game are in difrent directorys. the changes i made aren't working. what am i doing wrong.
Reply 13 of 15, by reble1950
i need to change the directory from the dosbox dir of "Z" to "c:\games\dgames\bstone" dir then start the game
Reply 14 of 15, by gidierre
why, you sure do but (as quickly remarked by Dominus) you also need to see that once you've mounted c:\dosbox as c: (why that btw?) to cd to your own c:\games\dgames\bstone dir there's no getting to it afaics
unless e.g. you start with
then you
-c c:
then
as opposed to: c c: cd\games\dgames\bstone which won't do
and finally there you go
or whatever is fit.
We often forgive those who bore us, but we cannot forgive those whom we bore. (La Rochefoucauld)
Reply 15 of 15, by reble1950
thanks for the info. i will make the correwctions later.
