First post, by Gamecollector
Dosbox 0.74,
The Hand of Fate CD 1.0a.
The game not show the final cutscene (with a lightning strikes the Malcolm's statue). After the phrase "sweetheart?.." - black screen, no response for any keyboard or mouse input (except ctrl+F9 etc). No messages in console also.
Any suggestions?
P.S. Final savegame is attached for testing. Use stick on middle gear. Then destroy Mr.Hand. Then test.
Reply 1 of 6, by bloodbat
Worked for me as it should, using your savegame...Malcolm gets struck and so and such, animation ends, exits to prompt.
Dosbox 0.74 SVN 3661, self built.
Perhaps your cycles are too low and it's loading the animation?
Reply 2 of 6, by Gamecollector
Cycles=auto 25000, so I doubt that is the problem...
Ok, I try SVN build and real DOS...
Updated: SVN 3661 - same results.
Reply 3 of 6, by rcblanke
Gamecollector, try with a default .conf (maybe except for the cycles setting), your machine and cputype settings may be the cause of the issue.
Reply 4 of 6, by bloodbat
rcblanke: you're most likely to be right, my .conf was set to svga_s3 and the cpu to auto.
Reply 5 of 6, by Gamecollector
Ok, after some testing I localized the source of this trouble.
The trouble only occur in the GM as music source and SB16/Pro as sound effects. So it looks like HoF error, not DosBox.
I do not have the hardware to test HoF in the real DOS with this settings, unfortunately.
Reply 6 of 6, by bloodbat
Funnily enough...those were the settings that I used for audio and worked for me.
