First post, by theoddling
Hello. I'm having troubles installing Daggerfall TES
I'm using:
AMD Phenom 9600 Quad-Core
1.88 Ghz, 4.00 GB of Ram
ATI Radeon HD 3800 Series
Windows XP 64 Bit Edition
The Elder SCrolls 2: Daggerfall version unknown
I'm new with dosbox so that might explain a lot. I'm having problems with mounting. I have extracted the files from bethesda softworks to a folder. I have a list of instructions on how to install with dosbox. I try to mount the location where I have the files extracted to but it says it doesn't exist. I can clearly see the file folder and I have clearly typed the correct path to the folder. I have read the readme files and nothing helped from there.
