First post, by Niels
I am trying to install a application which is called "snelstart" under dosbox version 0.74.
My operation system is windows 7
(Snelstart is a administrative program which works under ms-dos, I also work with it under windows-xp)
I get the start menu of the application, but when I want to start the real application I get the message that share.exe is not loaded, and that c:\share.exe will be added to the autoexec.bat file.
So I started up my old dos computer en got the file share.exe and put it in the dosbox.conf file. When I start dosbox I get the message that share.exe is the wrong version.
Does anybody know which version I have to use to make it work or does anybody has a workaround for this problem?
Thanx,
Niels
