Xcom:Apocalypse, Ascendancy and Eye of the Beholder 3
Having problems with a specific game or application? Post your problems here!
Postby greyseer_thanquol » 2003-10-28 @ 14:39
hi, new user of DosBox with troubles
I'm running DosBox on a Pentium4 1.8Ghz chip, GeForce 2 MX g.card, under Mandrake Linux 9.1. I've encountered these problems.
Xcom Apocalypse bombs during the install program - right after when I select any of the 3 install options.
Ascendancy won't run the install. If I copy the files manually and run it, I get an unhandled opcode. I'd take the advice on the SourceForge FAQ, and wait for a new version - but the games database states that it runs fine, so I'm not sure.:confused:
Eye of The Beholder 3 installs, but at runtime it gives "AESOP inheritance exceeded" and returns to the prompt.
Any help appreciated.
Avoid employing unlucky people -
Throw half the CVs in the bin.
greyseer_thanquol
Postby Darkstar » 2003-10-31 @ 00:37
When exactly does Eye of the Beholder 3 crash for you? It seems to run fine here (i.e. I can start the game, load the quick start party, walk around a bit and kill some monsters.
Are you sure you're using the latest version (0.60)?
--Darkstar
User avatar
Darkstar
Postby Melroc » 2003-10-31 @ 10:08
hmm... EOB3 also works fine on my machine...
btw... i'm using the german version...
User avatar
Melroc
Postby greyseer_thanquol » 2003-10-31 @ 12:00
I'm definitely using DosBox 0.60
After installing EOB3 and setting up soundcard, I run EYE.BAT. I get this immediately:
Error: AESOP inheritance limit exceeded
and then it dumps me back on the prompt.
Oh, and it's the English version from original source floppies
greyseer_thanquol
Postby Darkstar » 2003-10-31 @ 13:41
Strange. Maybe your eye.res file is corrupted?
Try it on a pure dos / win98 / WinXP machine. I have the english version and it runs fine (without sound, though) if I just launch it from the WinXP explorer.
--Darkstar
User avatar
Darkstar
Postby greyseer_thanquol » 2003-10-31 @ 14:35
I'll do that over the weekend (high-end Win98 machine at home, Mandrake Linux at work). I seem to remember it working on Win98, but that was some time ago - and floppies are not the most reliable media...;)
-- edited after weekend --
Ok, I've given up on Eye3 for now as I still need to finish the first 2 ;) . I also don't much care about X-COM Apocalypse, as it runs at home fine. Ascendancy would still be nice though - any help there?
greyseer_thanquol
Return to DOSBox Games/Apps
Who is online
