AUTOCAD 12 ON DOSBOX TELLE ME HOW...
Reply 21 of 25, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
maybe someone can close this. Doesn't sound at all like a legit owner of Autocad 12...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 24 of 25, by alneri
i might be too late but you can try this:
1. move all the files in a single folder.
include the disk.id of disk1 ( exclude other disk.id files).
2. edit the install.dat file and remove all @enddisk command except for disk12 & also remove all @disklabel command except for disk1.
now the folder including all files is modified to read as disk1 by the install.exe program.
3. mount the folder as a cdrom in D drive in dosbox. ( mount d: "folder path/directory -t cdrom -label "Disk1")
4. run install.exe
