Reply 20 of 25, by 1033Forest
Good utility. But what if I don't want to overwrite the palette, but want to just change the color of the text and background in DOSBox just like in Command Prompt with the color command?
So other programs will appear the way they're supposed to just the DOSBox prompt will have different color.
So like color 5e would show yellow on purple
Reply 22 of 25, by theshich
Sorry for necroposting this thread.
But once upon a time I took CHGCOLOR here and tried to improve it with concentration on CGA games.
There are some videos with the results.
1) Monuments of mars (there's no return back to cga default colors after mode switch (try CHGCOLOR and see what I mean), manual palette switch is shown)
https://www.youtube.com/watch?v=kyXxpoJRmWc
2) Popcorn (slowdown/acceleration, manual palette switch)
https://www.youtube.com/watch?v=kjvgAEPJqgQ
3) Alley cat (auto/manual palette switch also)
https://www.youtube.com/watch?v=mKNkKj-twxE
I'm not any good at programming DOS TSRs. But what do you think?
Reply 23 of 25, by dr.zeissler
4-greytones would be nice.
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 24 of 25, by Jo22
theshich wrote on 2021-03-14, 20:36:
Funny that you mention Popcorn.. 🙂👍
I've used it for testing purposes a while ago..
https://www.youtube.com/watch?v=cu88uKmqlEU
Popcorn uses an alternate palette already (red vs pink).
dr.zeissler wrote on 2021-03-14, 20:50:
Yeah, sometimes our eyes hurt so much we'd wish CGA had no colour..
With a real CGA and a video monitor (mono or PAL) it's easy to get rid of colour..
Or just use a VGA adapter that grounds pin 12 (mono monitor sense), so the VGA card goes monochrome.
Or use this: https://hackaday.io/project/166041-monochromevga
(Makes me wonder if that works with SCART, too. Take CVBS/VBS video and feed it into both
Green and Composite Sync, use a 3v coin cell to activate RGB Sense pin.. )
Edit: It's possible to turn any CRT TV/CRT video monitor in a monochrome display.
It's possible to manually adjust the potis for R/G/B on the driver board.
The colours not wanted can simply be turned down.
That's better than for the circuits than cutting off the R/B tube terminals if you want a green monitor.
Reply 25 of 25, by theshich
64 EGA color palette contains black, white and two greys. So it's not a problem with original CHGCOLOR.
Or I can fine tune more than fifty shades of grey for you because I use 18bit color.
