Blood
First post, by Comreak
I was looking through the game compatibility list at Dosbox.com and I saw that someone got Blood to run under dosbox. When I try to run Blood under dosbox, it doesn't quite work. It takes awhile to get through all the title images (with the publisher and whatnot) and when it gets to the blood intro screen, the video locks. I can hear the game sounds in the background but I can't do anything. Could someone point me in the right direction? Thanks.
Reply 2 of 8, by frip
Yep getting the same video pauses as yourself, if you turn off all features and sound these are reduced. The main reason tho is blood requires at least pentium 75. Dosbox can reach approx 486DX 100 currently, give this one some time.
Reply 3 of 8, by icemann
I thought Blood worked in every single last version of Windows so far? Doesn`t it work in XP? I`m a win98 personally so I`ve never tested it in XP.
Two stones, two crosses, the rest is just icing. - 7th Guest
Reply 5 of 8, by Comreak
Yep, did that when I tried to run it with WinXP/VDMsound. It works but it's laggy (strangely enough, it actually runs better). Thought I'd try it in Doxbox to see if it ran any better. If I turn up the CPU cycles enough, It'd probably run atleast as well as it does in XP (who knows what that kind of stress does to your CPU though). Heh, in a couple of years when I get my 5GHz processor, I'll come back and play Blood. 😁
Reply 6 of 8, by priestlyboy
Yes BUILD games have their problems but...
Using the latest CVS build i've had excellent time playing Duke3d.
I haven't tried Blood yet.
And i did play a little bit of Shadow Warrior.
It's a little jerky still but it works quite well.
Ieremiou
Reply 7 of 8, by Comreak
priestlyboy wrote:
Yes BUILD games have their problems but... […]
Ieremiou
Strangely enough, Duke Nukem 3d worked just fine with plain old VDMsound and WinXP. They probably made a few additions to Build when they released Blood. I'm sure the Build games will start to run better and better as tweaks and enchantments are made to dosbox's protected mode implementation.
