Bioforge
First post, by Jackal
Ok ok sorry. My problem. Someone wrote on forum that he can run bioforge. I tryed it. I ran bioforge: bioforge.exe. Game is starting:
BioForge, ver f1.01, (c) 1994,1995 Origin Systems Inc.
Memory:_
And than crash ! DOSBox turns off....
And DOSBox wrote: Maximum memory size 64MB, MIDI:Opened device:win32
and after crash: Exit to error: illegal descriptor type 1B for int 31.
Thanks for the help. And thanks to all peoples who did this !!! Its great, now i can play on WinXP Dune2 !! 😀)
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
I think you would have to use an cvs version. See in the development version for details
The offcial 0.60 release can not run it.
Water flows down the stream
Reply 3 of 4, by ChaosFish
CVS build is like a beta release, only that it isn't a realease. CVS is modified at the moment one of the programmers modifies the code, that means that no one tested it before you downloaded it. CVS is meant for use of the programmers only, but it's still fun to download and test it.
