First post, by conrad
The game runs...well, ok...but one thing is bugging me; it'll only allow me three reloads then DosBox crashes back to desktop.
For example, I start the game and die. So I load game X. Ok, I play some more, die again, then load game X again (or game Y, doesn't matter)
But the 3rd time I load a game, blooey!..back to desktop.
Anyone know if there's a config setting that controls this?
Thanks 😀
Reply 1 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
yes, it's a secret setting in the sdl section of the config.
Crashtodesktopontombraider1saveload=3
default is 3 and you needto set it higher. Don't set it to 0 or Tomb Raider crashes on starting up.
Seriously try the actual latest version of Dosbox.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 3, by Xelasarg
Try ykhwong's build http://ykhwong.x-y.net/). It might solve your problem, and it supports the 3Dfx version of Tomb Raider 😀
"What's a paladin?!"
