Help! Master of Magic runs slooooooowly!!!
Having problems with a specific game or application? Post your problems here!
Postby Alastre » 2003-11-19 @ 13:02
Hi guys, I couldn't get to make this game work with VDMSound , so I've downloaded Dosbox and now works ok. There's just a little problem,I can't run it in full screen but just in window mode. So I have to use DosBox without use doboxfro...the problem is that yes,the game works and the music too but...the game is SOOOOOOOO slow!!! Unbelivable...it's a shame coz it's not playable in this way...start a new game take about 4 minutes and when you are in, the units on the ground goes slooooooooowly! I have win XP pro, athlonxp2400+ ati9700 pro, etc etc etc..enought to make it run fine i think!!! Thank you in advance!!
Alastre
Postby Qbix » 2003-11-19 @ 13:11
try pressing ctrl + f12 a few times. with your systemspecs more than a few ;)
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby Alastre » 2003-11-19 @ 13:50
Thank you, but when i have to press them? while the game is running?
Alastre
Postby Qbix » 2003-11-19 @ 13:52
yes. You will notice in the title bar that cpu cycles changes
this is the speed dosbox operates at (it's not directly related to MHz though)
User avatar
Qbix
DOSBox Author
Postby Alastre » 2003-11-19 @ 13:55
i tried but it makes it more slow!!! I need to speed it up!
Alastre
Postby eL_PuSHeR » 2003-11-19 @ 16:42
Try using CTRL-F8 slowly. Hit it one time and see the results. This switch will skip frames, so don't use it too much, as video output will become very jerky.
User avatar
eL_PuSHeR
Moderator
Postby Alastre » 2003-11-19 @ 18:06
Hi, I tried it but situation hasn't improved...i'm becaming crazy!!! Why is it so slow????
Alastre
Postby quasarstrider » 2003-11-19 @ 20:20
I have WinXP, a slower Athlon than you have and onboard graphics. MoM runs fine and fast here.
Just press CTRL+F12 to speed up and CTRL+F11 to speed down. When the sound effects start stuttering, it is time to stop speeding up.
User avatar
quasarstrider
Postby jurgen » 2003-11-19 @ 20:22
It may also help if you set
scaler=none
in the config file,
this helps if the game runs at 320x200 resolution, then switch to full screen (Alt-Enter).
Also, try using General MIDI for music instead of adlib/sound blaster, this may save a few %cpu. (I feel like I'm repeating myself :-) )
User avatar
jurgen
Postby mirekluza » 2003-11-20 @ 06:46
Switching Windows desktop to 16 bit (instead of 32) also helps with the speed.
Mirek
mirekluza
DOSBox Moderator
Postby eL_PuSHeR » 2003-11-20 @ 08:21
Check your CPU cycles in the configuration file, too.
User avatar
eL_PuSHeR
Moderator
Postby Alastre » 2003-11-20 @ 16:55
I don't know why but now pressing ctrl+f12 the game runs much better..so thank you everybody!!!! :)
Alastre
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 2 guests
