First post, by Fiery Phoenix
So close I can smell it!
However I now have to post for help as I am stuck
I have the .bin file of Synnergist. I set this to load up in DosBox as an ISO
I run install in Dos and it install ok to my Virtual Drive folder as 21STCENT/SYN
I then add a game in DeFend - the file to start is the Synn application in the Virtual Drive folder folder.
In DeFend I also select the Drives option and select ISO Image (as drive D - same as when I installed the game in DosBox) and select the path as the original .bin file.
I load the game and it starts to boot normally (so the the installation paths above are configured correctly) but it then hangs on the words Loading Digital Driver
Everything before it states OK after it, including Loading Music Driver.
When I ran the install it auto detected my card and played a sample - was all ok.
Very annoying as I am not stuck - hence me coming here and hoping you guys can help.
Hope the info above makes some sense.
Reply 1 of 3, by Fiery Phoenix
Actually managed to get it to load now!
I was using auto detect when I should not have - set my own Soundblaster details and the game does load but now it hangs at the starting picture of an old house by the sea!
Even closer now!
Reply 2 of 3, by Fiery Phoenix
All ok - managed to get it going - somehow!
Reply 3 of 3, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
