windows millennium on... dosbox
First post, by ericvanhallen
so after an hour installing me on virtual box i though...
how hard could running it be on dosbox...
well i installed me with 98lite to remove the web integrated desktop crap (and after that it actually ran pretty good) and got it all in a 512.01 meg vdh file.
so i mounted it in dosbox with
imgmount c "C:\documents and settings\administrator\virtualbox vms\dosbox\dosbox.vdh" -size 512,63,16,20"
which mounted it fine.
i did a quick dir C:\ to see if it read the files and everything was there
so now on to attempting to boot it
boot -l C:
it loaded the 98lite splash screen (after installing 98lite it removes the original screen)
and crashed... but i rebooted it and got the familiar safe mode screen.
so i just selected safe mode and it only worked once (sadley no screenshot) and i got a mouse and the me scandisk program (to check if there were errors... there were) and it crashed after about 5 seconds of the scandisk
i did attach some screenshots though for proof (look at the safe mode screen).
now i did some investigation to all those errors in the console and before i booted it successfully the first time i had the -size params as
-size 512,18,8,80
which was just a blind guess... and it didnt even load the splash
but with
-size 512,63,16,20
it kinda works. so im going to tinker around for a bit untill i can resolve the illegal disk read/write errors. and get back to y'all.
oh and btw if anyone has any info on how i could fix those hard drive errors in the last screenshot please reply! the ability to run ME on dosbox would be a major (although not really worth cheering for) breakthrough. imagine all the extra windows programs that can run in the fast dosbox environment on linux/mac/etc etc
    22.13 KiB
    illegal hard drive read/writes... i have more than enough space on the vhd.
    17.44 KiB
    safe mode prompt
    23.46 KiB
    win9x splash screen after 98lite installation (works for me)
    21.89 KiB
    mounting the vhd as the C: drive
the cake used to be a spy...
Reply 1 of 10, by ericvanhallen
oh and a quick note. i did attempt the step-by-step option and it crashed right after making a decision on loading the msmouse driver. (whether or not you choose to). so that might be the problem.
Reply 2 of 10, by DosFreak
Those aren't hard drive errors. You are barking up the wrong tree.
Run Windows ME in a VM that supports it unless you have the proper skills to code support for Windows ME into DOSBox.
Make your games work offline
Reply 3 of 10, by ericvanhallen
oh sorry. i did a little research and your right. but i've already run me in a vm and i was attempting to boot the vhd file from dosbox (which partially works). but if you could tell me exactly what is causing the error (or what the error is causing) it would be appreciated.
Reply 4 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You are doing the equivalent of taking your hard drive with ME and sticking it into another computer that isn't the exact same built. This didn't work too well on real machines...
Better install windows directly on dosbox (there is a guide in the guides forum) but ME might not work at all. Other Windows 9x work. But don't work fine... and not supported
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 10, by Dominus
DOSBox Moderator
He he I hadn't even noticed the Dosbox 0.73 version 😉
But yeah the devs bumped version numbers for no reason, there were NO improvements to the code...
</sarcasm>
Reply 8 of 10, by sliderider
Has anyone else noticed that DOSBox 0.58 and 0.70 support more games than later versions? Why is that? Shouldn't compatibility get better in later versions rather than worse?
Compatibility statistics (3548 games in database)
Version: Games broken: Games runnable: Games playable: Games supported:
DOSBox 0.74 (410) 13 (3.17%) 6 (1.46%) 26 (6.34%) 365 (89.02%)
DOSBox 0.73 (588) 9 (1.53%) 11 (1.87%) 11 (1.87%) 557 (94.73%)
DOSBox 0.72 (699) 40 (5.72%) 21 (3.00%) 25 (3.58%) 613 (87.70%)
DOSBox 0.71 (142) 24 (16.90%) 5 (3.52%) 7 (4.93%) 106 (74.65%)
DOSBox 0.70 (940) 21 (2.23%) 13 (1.38%) 28 (2.98%) 878 (93.40%)
DOSBox 0.65 (714) 35 (4.90%) 27 (3.78%) 38 (5.32%) 614 (85.99%)
DOSBox 0.63 (908) 75 (8.26%) 42 (4.63%) 44 (4.85%) 747 (82.27%)
DOSBox 0.62 (391) 54 (13.81%) 24 (6.14%) 27 (6.91%) 286 (73.15%)
DOSBox 0.61 (996) 86 (8.63%) 57 (5.72%) 67 (6.73%) 786 (78.92%)
DOSBox 0.60 (767) 109 (14.21%) 65 (8.47%) 72 (9.39%) 521 (67.93%)
DOSBox 0.58 (1140) 263 (23.07%) 14 (1.23%) 19 (1.67%) 844 (74.04%)
Reply 9 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
human nature.
people don't retest games that already work and primary bother to report broken ones.
If you look at the percentages you will see that we've been around 90% for quite a while
Water flows down the stream
