First post, by Joey_sw
robertmo wrote:
Joey_sw
EXP: The Excellent Potato - PC-DOS (1996) works for me with proper speed. It is definitelly not too slow, actually if it was any faster it would be too fast. If you still have a problem with this game start a new tread about it posting your pc configuration and dosbox configuration.
For example it takes 10 seconds to walk from left to right city wall (at the bottom there are no obstacles). Same speed on real Pentium 166 MMX.
Thanks for replying.
Yes, it almost the same here, when not battling enemies.
However, when entering battle, the games slowing down (but pressing Alt-F12 makes it goes too fast).
my System:
Intel Core 2 Duo E7500  E7500  @ 2.93GHz
Wolfdale, Socket 775 LGA
Motherboard:
Intel G41 rev. A3
Intel 82801GB (ICH7/R) rev. A1
DDR3 - 2048 MBytes
Display & Sound onboard:
Intel(R) G41 Express Chipset
onboard Realtek HD Audio chip
OS:
Windows XP Professional SP2 (Build 2600) (x86)
DirectX 9.0c
i'm using DosBox 0.74 from main site.
as dosbox configuration, i use standard from dosbox -resetconf ,
with following addition on [autoexec] section:
@echo off
mount C "D:\GAMES\Exp"
c:
loadfix -32 exp.exe
exit
theres new fact i found about the slowdown:
under normal gameplay using above configuration, CPU Usage was about 38% to 45%
however on battle when slowdown happened, CPU Usages was strangely used only about 25% to 31%,
definetely resulted in slowed scouting animation & battle music.
after completed the battle / exp/item get screen gone, cpu usages return to 38%-45%.
probably something going on on my system that causing this.
-fffuuu
Reply 1 of 18, by robertmo
it looks like using less cpu with max cycles during battle for me too, but i think the speed is ok (actually it is indeed slower than on my p166mmx).
you can try the latest dosbox http://www.emucr.com/search/label/DOSBox
it won't hang in intro
is the intro speed ok? (at the begging when first text appears)
have you got vsync enabled/disabled in your gfx card configuration?
have you tried fullscreen?
and fixed amount of cycles? (how many)
Reply 4 of 18, by Joey_sw
Thanks for SVN build, with it i no longer need to use loadfix for some other games too!
Intro speed seems to be ok.
As for vsync, since i'm using onboard intel graphics, i found no such configuration on intel-display control panel. (unlike with nvidia or ati drivers)
Fullscreen behaves the same, i found no difference.
And for the cycles, i unable to find proper setting that would lead to 'correct' fighting speed.
I've tried to set the cycles to fixed amount, but the slowdown at fight still happen with its drop of CPU usages.
if i remember correctly, even with the slowdown, the sound (music & sfx) pitch/frequency were correct, almost if the game calculates and using wrong delay values.
-fffuuu
Reply 9 of 18, by Joey_sw
AGB wrote:
Hello. So - were you able to run EXP? If so - have you made after this place? http://i.imgur.com/2UbibRp.png […]
The stuck are known problem which caused by faulty copy from defective media.
As the game publisher goes defunct, you probably unable get another legit, good-copy of this game anymore,
therefore the remaining workaround for this problem is to edit the saved game.
Just make a save after you beat the two soldiers and upload it,
i'll edit the saved game so you can continue the game story.
save#1 saved as GAMEDATA.0
save#2 saved as GAMEDATA.1
save#3 saved as GAMEDATA.2
and so on ..
I also recommend this experimental version of dosbox to play the EXP,
look for attachment in ripsaw8080 post.
In that version the battle speed are fixed as it should, but its require loadfix to pass the intro screen properly.
loadfix -28 exp.exe
-fffuuu
Reply 10 of 18, by krusade
hey! I've been looking for this game for years. I cant seem to find it now.. mind if you can help me? if its not allowed to post a link here.. can I ask for a pm? thanks. I played this when I was a kid. I was stuck at the same part.. I haven't finished the game
Reply 13 of 18, by AlphaHari
Could anyone direct me where is to find this game? I am playing when I was a child long time ago. I want to download and play this game once again, if possibly with translation to english
Reply 17 of 18, by AlphaHari
AGB wrote:
Here is an answer in the comments for EXP video in Yuotube: https://www.youtube.com/watch?v=dFc0dKFj3rw
Did you stuck here?
Yes that is right, i just using HxD to edit but too bad i want see 2 events that we skip 😕
i heard that editing for seeing 2 events is complicated
