First post, by Jamesapp
Hello,
I have a MacBook pro laptop running mac os x 10.7 lion.
I have been fooling around with a speech synthesizer on my mac. I have tested the synthesizer on my mac. I have a serial2usb adaptor and I have installed it's driver. I have been able to use the synthesizer with my mac. I sent text via the terminal and have gotten output. My serial device is located on my mac at
/dev/cu.usbserial-FTKVMAFF
A utilities disk written for dos came with the synthesizer. And there are some utility programs that I wanted to run. So my question is about serial port set up and dosbox.
I have edited the config file by editing serial1, I edited it as follows
serial1=realport:/dev/cu.usbserial-FTKVMAFF
I have also tried
serial1=realport:COM1 realport:/dev/cu.usbserial-FTKVMAFF
When I run a test program which was included with the synthesizer, it says my synthesizer isn't working properly?
Is the realport the /dev... directory on my mac? Is it possible I have to set up communications like baud rate parity etc in the config file?
Also is it possible my synthesizer is acting as a modem. When trying to get the synthesizer to work, I do remember reading or someone telling me that it is possible the synthesizer is acting as a modem.
Anyway any help would be appreciated.
